AO Smith GPVX - 75L clinking noise
zmann96
Member Posts: 29
I just purchased a 75 gal HWH for my radiant heat. It was delivered yesterday. When the lowered it off the truck it was still on a shipping pallet. I tilted it from side to side to walk it into my garage for storage until I need it. I noticed a clinking noise and seemed to come from the top. I know there are tubes running down but are they supposed to be loose? I took a video with audio but can't seem to attach.
Hi, Could you put the video up somewhere else and post a link? It would be good to hear it.
Yours, Larry0 -
I put it on youtube. remember the tank is empty.
https://www.youtube.com/watch?v=TCubi_3Ibvg&feature=youtu.be 0 -
Hi, If it's a gas fired heater, that could be the flue baffle clanking around. Pull that up and out and see if the noise happens anymore.
Yours, Larry0 -
Ok, I'll try that. It's got the direct power vent so I'll have to remove that.0
LARRY , i TOOK THE POWER VENT OFF AND SURE ENOUGH IT WAS THE BAFFLE MAKING THAT NOISE. THANKS0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
