Busy signal
gstewart04
Member Posts: 1
I have a Mitsubishi hyper mini split.
When the unit is in heat mode the wall unit i
s making a busy signal sound. This noise goes
away in cool mode. The sound is loud enough
to keep you awake at night, I have turned up
the air cleaner to drown out the noise.
Anyone ever run into this.
Some have a minimum lineset length and can make noise if it’s too short. I think liquid velocity becomes too high.0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
