Gas pressure check
55Trucker
Member Posts: 20
in Gas Heating
I have a Laars Mascot FT boiler. I would like to check the out pressure of the gas valve, but there is no spec for the size of the test ports. I measured the plug diameters at .1905", or almost 5mm. I am assuming that I can't just slip a neoprene tube over the test port, that I need something with a barb screwed into it? I've attached a couple of pictures of what I am talking about. Any advice that you can provide will be greatly appreciated. Thanks.
Thank you!0
Some are 1/8" pipe thread. You can get a fitting 1/8" MPT x barb0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
