New Weil-McLain Combi sneak preview
  • STEVEusaPA
    Doesn't modulate?
  • GroundUp
    GroundUp Member Posts: 2,461
    Doesn't modulate?
    "Up to 10:1 turndown" on the top of page 9
  • STEVEusaPA
    Missed it. Pretty important, that should be on page 1 and mentioned a few times. :)
  • kcopp
    kcopp Member Posts: 4,614
    Minus the control it looks pretty much like the Triangle tube Instinct
  • Tim_D
    Tim_D Member Posts: 131
    WM proprietary design. Everything was designed and assembled by the WM engineering team in Michigan City. As far as I know we have not done anything with TT since the Plus Indirect days.
    Robert O'Brien
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    So W-M is now building their own fire tube HX and not outsourcing their burners/HX as a unit from AIC? Will this replace their ECO line I wonder?
  • Tim_D
    Eco is discontinued as is the WM97. The modcon line up will be Evergreen, EcoTec, Ultra and Aquabalance. The combi line up will be EcoTec and Aquabalance. The HX is manufactured for WM not by WM and it is not AIC. The Evergreen will continue to be an AIC HX.
  • flat_twin
    flat_twin Member Posts: 354
    Oh cr*p! I better start expanding my own stock of replacement parts for our Eco before they're no longer available.
    kcopp
  • Tim_D
    ECO will be supported for several years.
  • flat_twin
  • BillyO
    BillyO Member Posts: 277
    I like this boiler
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Looks good!!
