New Weil-McLain Combi sneak preview
Tim_D
Member Posts: 131
The EcoTec will be available July 1.
1
Doesn't modulate?
"Up to 10:1 turndown" on the top of page 9STEVEusaPA said:Doesn't modulate?
Missed it. Pretty important, that should be on page 1 and mentioned a few times.
Minus the control it looks pretty much like the Triangle tube Instinct0
So W-M is now building their own fire tube HX and not outsourcing their burners/HX as a unit from AIC? Will this replace their ECO line I wonder?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Eco is discontinued as is the WM97. The modcon line up will be Evergreen, EcoTec, Ultra and Aquabalance. The combi line up will be EcoTec and Aquabalance. The HX is manufactured for WM not by WM and it is not AIC. The Evergreen will continue to be an AIC HX.0
Oh cr*p! I better start expanding my own stock of replacement parts for our Eco before they're no longer available.Tim_D said:Eco is discontinued as is the WM97. The modcon line up will be Evergreen, EcoTec, Ultra and Aquabalance. The combi line up will be EcoTec and Aquabalance. The HX is manufactured for WM not by WM and it is not AIC. The Evergreen will continue to be an AIC HX.
ECO will be supported for several years.
I like this boiler
Looks good!!0
