Anybody know what this is?
New England SteamWorks
Member Posts: 1,529
Found in boiler room with Warren Webster vapor system.
newenglandsteamworks.com
I assume you mean the 3 drain/drip/vent pipes.
I have seen something similar on dry returns. Some coming from F&T's.
Helps isolate which return branch has bad traps passing steam.
I added more as possible to the project.
Kept steam out of the cond pump also.0 -
The basement is finished, so I can’t see where they are coming from. Not even certain they are connected to the steam system. But there is only one F&T trap, and they are not connected to it. The little pipes are very old though, definitely same era as the steam system.New England SteamWorks
newenglandsteamworks.com0 -
Any evidence of water drips inside the pipes or drain pan?0
NoneNew England SteamWorks
Blow down discharge drip tray ?
I saw one that was very ornate years ago. Was beautifully designed much like so many radiators we have all seen. At least that is what I saw and what it was used for.0 -
Blow down of what? It’s 1/4” pipe...New England SteamWorks
Possible strainer blow down? Or maybe a flash tank overflow?0
Hmmm.....1/4' pipe? Didn't read that they were 1/4". Stumped here. The ones' I saw had 3/4" and 1" discharging into this ornate bowl.0
The ones I have seen were 3/8 to 1/2" IPS.
1932 school, 2 pipe, attic main downfeed with pumped return.
Multiple dry returns and EOM drips and F&T's.
Warren Webster rad traps and inlet valves. Plain jane piping to returns. BTW, what would qualify it as a vapor system??0 -
What kind of building is this? How old? An older apartment building would have had iceboxes before electric refrigerators, and those might be the lines that drained the melted ice away.All Steamed Up, Inc.
Consulting4 -
It’s a large single family home, 1920’s. Ice box idea sounds plausible, except: why 3?Steamhead said:What kind of building is this? How old? An older apartment building would have had iceboxes before electric refrigerators, and those might be the lines that drained the melted ice away.
1/4" is pretty small for any drain without pressure, IMO.0
Some buildings Had Hoffman # 3 air vent valves. The discharge port of each valve was piped to a main terminal in the basement or or piped to the outside of the building near the radiator.
All I can think of is if there is one pipe per radiator these pans were used to capture any condensate that escaped the heating system when the vent valves discharged air.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Those #3 vents were designed to be used with Paul and similar air-line systems, where the vent lines led to an exhauster that pulled the air from the system. I doubt they would have been routed to a dry-sink like that one.All Steamed Up, Inc.
Consulting0 -
Where does the tray drain to ?
There is a cut-out in the cement floor for the water meter, and it just drains into there.New England SteamWorks
Cuspidor.Just another DIYer | King of Prussia, PA
If eventually draining into the dirt, it seems not much water was passed.
I'm sticking with my "the steam in return line/failed trap or orifice / pressure too high "theory.
Or another WAG would simply be air vents for dry returns.
How many steam mains in the house?0 -
It could be drains from a old icebox ,... But why three ?
That looks like a home made "air gap" that is usually required in a commercial building to prevent sewer water from contaminating a potable water source like a drinking fountain in case of a sewer back-up. I used to see these in mansions of the very wealthy. Just a guess. Today, they use fancy air gaps made by a commercial vendor.0
