Buderus indirect hot water tank temp sensor
RickW
Member Posts: 3
I am using a Buderus 160/1 indirect hot water tank. I have the Logomatic DHW temp setting at 130°. Lately the water has been scaulding hot. I am guessing the temp sensor is bad but, in lieu of just replacing parts, does anyone know the normal ohm values for this sensor? Note, I am not getting any error codes on the display
Thank you
Thank you
I've seen 10K and 20K sensors, but this looks like a 1.5K sensor, no?
Looks like 12k to me. Typically the resistance of a thermistor is specified at 25 c however there are a could other parameters you need to be able to calculate its resistance at any other temperature. There are dozens if not hundreds of types of thermistors with different curves.0
Thank you HVACNUT, Alan, and Mattmia2
If the chart shown is correct (I found the same chart in the service manual) at 190° I measued 1.89 ohms. So I guess I remove the sensor from the tank, let is cool down, and remeasure. If okay, then back to the drawing board ...0 -
According to the chart at 190 degrees F it should be a little over 1 k ohm.0
Thank you, Mattmia2 yes I should have mentioned kiloohms. Turns out I read the wrong sensor. The dhw sensor "FB" according to the manual, read 2.76kohms0
- 123 Chimneys & Flues
