The oldest German radiators
DanHolohan
Member, Moderator, Administrator Posts: 16,732
Is that piping lead?
They look a lot like the radiators that heat the Henry Ford Museum with the tank and tube design.0 -
Yes, the Ford Museum. That’s what I thought too.Retired and loving it.0
Steel.mattmia2 said:Is that piping lead?
Men were stronger back in those days.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
It makes me wonder if they used DeLeval's turbine-driven pumps, as they did in this building: https://heatinghelp.com/blog/nycs-first-very-large-hot-water-heating-system/Retired and loving it.0
I don't know about the pumps. It being a museum there is probably extensive documentation somewhere. I'm sure the heating plant is a work of art and museum in itself.
It was built in 1929 so utility power should have been available at that time however it is also near a lot of Ford plants so it may have got(may still) get steam from the powerhouse for a Ford plant. I know when they demonstrated the steam engines they powered them from compressed air from the Ford plants. I remember seeing the engines demonstrated as a kid. I don't know if they still do that. There was an incident about 30 years ago and they stopped demonstrating them because of that. I don't know if they have put in place better safety practices and resumed demonstration.0 -
Thanks for sharing that gem . It’s been over 20 years or more since I have been to Germany but while there I loved the way they hooked up rads and do there piping after the war it was like they used what was on hand and made it work . When I would go and look at the new projects that where done say 30 to 40 years before I was there the attention to detail and quality of there work really had a impact on me and even though every place I had work always though and spoke highly of my work ( level square properly supported) but upon returning from Germany I had gotten a bit more anal w my work and took big hints from the Germans , I started install dbp valves pumps and zone valves on the supply , check valves on indirect tanks and doing heat loses for jobs . At that point I was already installing ci buderus boilers nobody really had heard of them and most refused to pay the extra couple of hundred for them very foolish . We installed a lot of them for quite a long time Until there dist locally kinds faded and then drop there gas line of boiler to just the gc model . I really have to thanks the Germans for putting a flame to my butt and to Mr H for putting the knowledge for all to learn . Thanks for the memory peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
I ate there when attending the ISH show in '93. First class restaurant and very elegant. I couldn't get permission to see the boiler room, but was impressed with the setting.
I couldn't get into the boiler room. But I spotted that radiator in a room that the waiters were using. I asked and they moved that curtain to give me a better look.Retired and loving it.0
I didn't know you speak German.DanHolohan said:I couldn't get into the boiler room. But I spotted that radiator in a room that the waiters were using. I asked and they moved that curtain to give me a better look.
Americans....gesturing.....lol
I'd be willing to bet a Vie$$man or two is hiding out there.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
I'm surprised that they would have been so late to be the first (or currently the oldest), but then again, Germany is big on tile stoves.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
