N
JPL941
Member Posts: 51
Hello
Please take a few pics of the installation and the plastic? pieces and post them here.0
Shouldn't be a worry. Go ahead and empty the debris out.0
That is just "PVC sawdust" from cutting the pipes in place without dumping the cuttings out.
You may have to empty the trap several times.
Can you see any debris in the air inlet pipe, is it connected directly to the fan or just opens into the cabinet?0 -
If properly pitched the exhaust will cause condensation from the flue gas to drain back to the boiler. This will cause the PVC sawdust to migrate back to the condensate trap. I would not worry about it. There are many other things the will also accumulate in that trap over the years. Just have the maintenance done every year according to the manual. Proper maintenance will keep the machine working dependably.
Neglect will result in premature failure and nuisance service calls.Edward Young Retired
T
Just clean it yearly, this happens all the time....
Watch for dirt in trap
We recommend owners clean these traps twice a year....0
