EDR Missing in book???
mugenmundo
mugenmundo Member Posts: 1
I have the following radiator. I looked thru the book and tried to determine the EDR with no success. Anyone have a clue of the manufacturer or EDR?
    EBEBRATT-Ed Member Posts: 19,398
    Really old.
  • unclejohn
    unclejohn Member Posts: 1,833
    Just measure and find something close in the book. Or use the paint method. But you have to use really old paint.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    You could wrap a tape measure around the oval tubes, then measure the length of each, and finally the number of tubes.
    So circumference (Inches) times length (inches) times number divided by 144 should equal the square feet. —NBC
  • Fred
    Fred Member Posts: 8,542
    Check Imperial Two column radiator, page 75 of the "EDR" "Every Darn Radiator" by Dan Holohan
    Steamhead Member Posts: 18,179
    Looks like a standard type of 2-column radiator, @mugenmundo . If you can post the height, depth (front to back of each section) and section spacing (distance between the center of one section and center of next one) we'll know for sure.
    Consulting
