Peerless G561 boiler
amyj
amyj Member Posts: 1
Main water supply is off for weekend. Can I manually add water to furnace? If so, how?
  • Are you having to add water regularly? Has the low water cutoff stopped the burner Frequently?- not a good sign.—NBC
  • neilc
    neilc Member Posts: 3,174
    anyone else notice pressure gage over 15, and no pigtail under Ptrol?
    amy, what's that grey box set at on the scale, post a picture.
    there's also a white wheel under the cover, should be set at 1.
    is that floor wet? like leaking from the boiler, or pipes ?
    known to beat dead horses
    SuperTech
