leak breaker
Snowmelt
Snowmelt Member Posts: 1,457
this is for you taco guys, last month I went to get a leak breaker for a customer, he supply house and the local rep told me that taco wanted to do an upgrade to them with an exercise feature so they don't seize. the local rep also told me that they should be done by now, is there any update on that product?
  • SteveSan
    SteveSan Member Posts: 293
    @Snowmelt Taco is doing a product enhancement to have an exercise function on the actuator. If you install the product at 2pm, in two weeks it will actuate the valve to open and close. If you would like to change that time you can either cycle the valve by the open and close feature at the time you want it to or just cycle power at the time you want the valve to exercise. We are able to produce about 600 a day to fill open orders. I have looked at supplyhouse.com and they have them in stock now. Any questions you can call me ( Steve ) at 401-942-8000 ext 328 or Tom at ext 374. I am here 8am-4:30pm and Tom is here 8:30am-5pm EST.
    Henry
  • Snowmelt
    Thanks steve
  • SteveSan
    You're welcome!
