Radiator
loftylandy65
Member Posts: 2
Is there any reason I cant install a radator on a sloping wall ?
Steam or hot water? In either case you can shim it out where needed, If steam just make sure the radiator pitches the right direction.0
It would be hot water rad on sealed system on an approx. 45deg wall
- 121 Chimneys & Flues
- 15.8K Strictly Steam
