Are Watts relief valves low quality? Are there replacements that are better quality?
2»
  • rccrfan
    rccrfan Member Posts: 51
    I just ordered the Apollo and some blue monster dope. I'm also going to use some copper and get rid of that PVC they put.
    As far as the coupler I don't like having to tighten something that doesn't have a flat sides- I never feel as though I have tightened it enough!
  • SuperTech
    SuperTech Member Posts: 2,659
    If it leaks a little bit and needs to be tightened it's easy enough to do so. If you over tighten and crack the fitting or whatever you are screwing into that's not as easy to resolve.
