Indirect tank heating
Coolmen
Homeowner sent this to me and I think is overkill. Wanted to see what you guys thought.
Is a 80 gallon only used with left boiler with zone valve.
looks like a buffer tank attempt?Bob "hot rod" Rohr
If unit 1 fails he want to be able to open valves so unit 2 can heat for him until unit 1 is running again.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
