Smoking....
STEVEusaPA
Member Posts: 6,505
Does that have something to do with something shorting or is that because the terminal wasn't soldered right or someone torqued on it enough to loosen the solder joint or just didn't tighten the screw?0
Looks like it shorted. No field soldering on those controls. Doubt it was torque, as no one probably touched those wires since in was installed in the late 80's.
To me I think it was the wiring itself. Older wire that has cloth-like insulation inside the MC, falling apart inside the control. No black marks on L2 (also no ground).
All wiring replaced now. I posted a picture before of the whole mess, circulators with zone valves as check valves, and contactors/relays galore...
I love zone valves as flo-checks! Double the fun!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
I meant the terminal where it was soldered to the board at the factory, it is common n all sorts of other PCBs, especially where it is high current although those usually show up more in the 10 yearish range (or the pads on the board weren't big enough and it just failed over time).
Another thought i had was that a wire was folded against the terminal and chaffed after decades of vibration.
Since I don't see a clean area where the wire was contacting the terminal under the screw, my biggest suspect is the screw wasn't tight enough and over decades of heating and cooling and vibration it loosened up and burned up.0 -
Why not whip out yer soldering iron and do a field repair?0
I always said that it doesn't matter how good a service tech. you are a part will fail.0
I had a triple aquastat burn up like that once. They smell terrible. Never figured out why it happened. Installed a L7224U and the boiler was good to go.0
- 167 Indoor-Air Quality
