Tekmar
BillyO
Member Posts: 277
in Gas Heating
Is there a thermostat available that does 2 stage cooling and 1 stage heat with floor sensor. figured I would start here
I don’t do much Tekmar, but prolly more that the average dude. Not sure that exists; you may need to call Tekmar on that one.0
Thermostat does no do 2 stage cooling. It is your cooling unit that decides that. If you have radiant, your radiant control system will control the heat. You only need 2F of temperature differential: Heat to 70F, cool at 72F, as in my house.0
Typically the radiant controls are dedicated to just that- radiant. But I don’t know the answer 😀0
