Radiator
skibum
Member Posts: 7
I'm sizing a steam system and cannot find this radiator in the EDR book. It is probably in there but I just haven't been able to locate it. Can anybody put a name to it so I have some idea where to look? Thank you.
Sunrad0
This is the best info I could find.
https://files.gitshare.io/link/rBDNg1g1CSM/Radiator-Baseboard Product Data Sheet.pdf0 -
Burnham lists these radiators as "Radiant Radiators" and shows them to have an EDR of 2.25 sq ft per section for the 5" depth and 3.4 sq ft for the 7.5" depth rads. Their height is shown to be 20". You can also go to U.S.Boiler company, click on products; product selection; and radiant. Hope this helps.0
https://heatinghelp.com/assets/documents/192.pdf
From the Museum, EDR is 2.0 or 3.0 sqft per section depending on the dimensions.0 -
Thank you guys, this should help.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
