No heat/Hot water
salisboss
Member Posts: 34
I was purging my system and while trying to change the AAV I got a lot of overspray. The top of my boiler got wet but no any of the electronics. However now my gas igntion is locked out. Help
I tried to reset the ignition a few times and on the third time it finally took.
Edit: The system is climbing back up to temp. Sorry to panic. Google is fantastic when you can just search the part number and get the manual.0 -
What's an AAV?
Did your primary control lock out because you got water on it or is there something else going on that caused it to lock out?There was an error rendering this rich post.
AAV - auto air vent
I think the flame went out from the water getting inside.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
