Rinnai E110C COMBI
Bill Julian
Member Posts: 164
in Gas Heating
I have a situation (at my house too).
The low loss header tank (drain kit) below the boiler. Well, I bumped into the drain and purge connection (dummy) and the 1/4" fitting broke off and now the 1/4" brass is stuck in the header. I tried tapping it didn't work out. Never had this happen atleast its my house I can deal with it. Might have to go another route. Any Thoughts?
drill and tap.
Tried it did not hold. Have to replace.0
Can you drill and tap it for a larger size?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Wondering if I can weld the hole?0
You may be able to braze a new fitting in, post a picTom
Montpelier Vt0
- 109 Chimneys & Flues
- 976 Plumbing
- 387 Solar
- 17 Recall Announcements
