Burnham heat pex from 2001
MikeL_2
MikeL_2 Member Posts: 531
edited January 2020 in THE MAIN WALL
Does anyone have experience with heat pex branded Burnham? A rep from US boiler I spoke with thought it may be a re - branded Wirsbo product. I'd like to confirm the tubing is expandable before I try to repair a leaking joint......
    hot_rod Member Posts: 25,124
    kcopp
  • MikeL_2
    Thank you, Bob. I emailed that company for some information.
    looks like thy offer pex C, at least now.
    I would only expand the A pex. Although some B pex manufacturers are promoting expending B. Some tests I have seen are not so conclusive about expanding B pex :)
  • MikeL_2
    I heard back from Hewing in Germany; they say the tubing is not theirs. I wish someone from US Boiler would chime in on this like Energy Kinetics, Taco, and other manufacturers do. ....
    Here is what Burnham claimed when it was introduced?
  • MikeL_2
    Thanks again, Bob. I forwarded the article to the person who contacted me from Hewing.
  • Dave H_2
    Dave H_2 Member Posts: 612
    @MikeL_2
    I remember those days from when I was with RTI (also an Uponor company), the Burnham pex from back then was from Hewing and Hewing was (at least back then) associated with Uponor.
    However, Hewing only made a pex-c in those days so I would not expand it.
    You should be able to use any other compression fitting.
    Dave H.
    Dave Holdorf
    Taco, Inc
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    My thoughts exactly. Why not simply use the copper crush ring system to be safe? I use them on PEX-A,B ,and C. Dont get me wrong, I expand wirsbo/uponor and Mr.PeX too, but sometimes the crush rings (not the side cinches) work great.
    If you do a fitting requiring crimp rings, I like the stainless collars best, copper rings next. I think the pinch style cinch rings are a crappy look, sharp and often the pex turns easily after pinched.
    I think Sioux Chief offers all styles of pex fittings and rings now, expansion, copper, stainless crimp.
