NO HEAT CALL
Intplm.
Member Posts: 2,803
I once got a no heat call to a 90+ furnace I had installed just a week before. I removed the failed inducer to find a bird all the way inside the housing. I also had to change both.
Does that squirrel create a problem???0
I’d better go check my intake to make sure the screen is still there0
The squirrel came down the 80% exhaust pipe I do believe.0
I had that, except a Radon fan. Didn't notice it was silent for a long time. Started sawing it out of the PVC pipe. Smelled bad. Hair in the saw-teeth. Then I felt bone. Got it out and I about barfed in the basement.
That's why my furnace has had air/smoke screens from the first day. And when the smoke screen started to rust out I replaced it with an SS screen.0 -
Farmers Almanac is predicting a very cold winter... This must be true because all the Squirrels are gathering a record amount of nuts. So many that a few of my friends are missing.
Just checking to see if anyone of the usuals from HH are missing?Edward Young Retired
(groan)EdTheHeaterMan said:Farmers Almanac is predicting a very cold winter... This must be true because all the Squirrels are gathering a record amount of nuts. So many that a few of my friends are missing.
Just checking to see if anyone of the usuals from HH are missing?All Steamed Up, Inc.
Consulting2
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
