Most popular wrench of it's time
BobC
Member Posts: 5,535
This bit of history ran in the Boston Sunday Globe Magazine today (Dec 8, 2019)-
https://www.bostonglobe.com/2019/12/06/magazine/forgotten-story-americas-most-famous-tool/
3PSI gauge
3PSI gauge
1
The attached picture is of a wrench I bought at Harbor Freight. The label says "Pittsburgh Stillson Pipe Wrench." As you can see, it's clearly not a Stillson wrench. It's a pipe wrench patented in 1888 (19 years after Stillson received his patent) by a Swedish inventor named Johan Petter Johansson. I bought it mainly as a curiosity; I haven't found it very useful. There's nothing in particular that it does any better than—or even as well as—the Stillson.
It wasn't made in Pittsburgh either.
this is a REMS version, I found it very handy for 1/2, 3/4 & 1" gas pipe work, light, quick to adjust and it was almost impossible to over-tighten threaded pipe with it. An aluminum version would be ideal.Bob "hot rod" Rohr
I wonder if I'd like mine better if the jaws were at the same angle as yours. The jaws on mine are perpendicular to the handle, but yours are ~135 degrees.Just another DIYer | King of Prussia, PA
Mine also have a rounded or V shape section on the front that grabs pipe nicely. Yours look like they would be better for nut and bolt work?Bob "hot rod" Rohr
This is the one for nuts and bolts.
I have some stillson wrench’s out in the shed and a bunch of those rems what I call German plumber channel locks I have them in offset and about 24 inch . There great for tight spaces . Peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
