Most popular wrench of it's time
BobC
BobC Member Posts: 5,535
This bit of history ran in the Boston Sunday Globe Magazine today (Dec 8, 2019)-
https://www.bostonglobe.com/2019/12/06/magazine/forgotten-story-americas-most-famous-tool/
3PSI gauge
Grallert
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    The attached picture is of a wrench I bought at Harbor Freight. The label says "Pittsburgh Stillson Pipe Wrench." As you can see, it's clearly not a Stillson wrench. It's a pipe wrench patented in 1888 (19 years after Stillson received his patent) by a Swedish inventor named Johan Petter Johansson. I bought it mainly as a curiosity; I haven't found it very useful. There's nothing in particular that it does any better than—or even as well as—the Stillson.
    It wasn't made in Pittsburgh either. ;)
    hot_rod Member Posts: 26,391
    this is a REMS version, I found it very handy for 1/2, 3/4 & 1" gas pipe work, light, quick to adjust and it was almost impossible to over-tighten threaded pipe with it. An aluminum version would be ideal.
  • Hap_Hazzard
    edited December 2019
    I wonder if I'd like mine better if the jaws were at the same angle as yours. The jaws on mine are perpendicular to the handle, but yours are ~135 degrees.
    Mine also have a rounded or V shape section on the front that grabs pipe nicely. Yours look like they would be better for nut and bolt work?
  • Hap_Hazzard
    This is the one for nuts and bolts.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,681
    Here's more about Mr. Stillson:
    https://heatinghelp.com/blog/daniel-chapman/
    Retired and loving it.
    Hap_HazzardGrallert
  • clammy
    clammy Member Posts: 3,241
    I have some stillson wrench’s out in the shed and a bunch of those rems what I call German plumber channel locks I have them in offset and about 24 inch . There great for tight spaces . Peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
