Help in San Diego?
Hi all - I have a two-pipe steam radiator system in my 1926 house in San Diego, some radiators work, some don't, boiler is good, pressuretrol set correctly, etc. I suspect steam traps may be an issue, or gunk in the return somewhere.
I'd like recommendations for qualified repair people in the San Diego area - I haven't been able to find any.
Thank you!
  • Visit the wholesale plumbing/heating supply houses and ask for recommendations.
    Even someone who is retired could be a start.
    The traps would be a good place to start-search here for testing traps for the procedure.
    Even one open trap can shut down the others on the same main.—NBC
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    You need heat in San Diego??? :D
  • STEVEusaPA
    Yeah it gets cold there, especially when the wind is whipping in. Not like winter back east, but you need heat.
    I’d be curious to see pics of a house in San Diego that has steam.
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,307
    I'm usually there in the spring, but quite busy right now in the windy city.
