Standard Oxygen Barrier pex or Pex-Al-Pex for staple up radiant heat?
grant_andrew
Member Posts: 22
I’ll be adding staple-up radiant heat to my ~120 sq. ft. kitchen in a few weeks, and I was wondering if anyone feels strongly about using regular oxygen barrier pex versus pex-al-pex for the job. I just re-piped my boiler’s old 1¼” and 2” cast iron to ½” PAP using a homerun manifold setup, and I found the PAP really easy to work with. However, I wasn’t snaking it through floor joists like I would be on this job.
It’s such a small job that the cost difference between the two will be minimal, so I’m really looking for any ease-of-installation or performance benefits for one or the other. Any thoughts are appreciated, thanks!
I like a PEX-A such as Wirsbo/Uponor or Mr.PEX etc. Or PERT, from Watts. All easy to work with.
I'll second the extruded Aluminum transfer plates.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Great, thanks!
Do you prefer the extruded plates because they're easier to install, or because they give better heat transfer than the sheet metal ones?0 -
I used the thick extruded plates that the PEX pushes into. Everything I read said that they would give better heat transfer than the thinner plates that fit over the PEX. I also read that the extruded plates would reduce ticking and popping sounds during warm-up. My system works as designed, so I can't complain, and it is silent.
Re: installation, it's a lot easier to put the PEX into the extruded plates, I think. I installed the extruded plates using 1" self-driving hex-head screws, so it was pretty easy to put them up.0 -
I have used sheet metal transfer plates. I sprinkle on baby powder on the grooves before snapping over the pex. It stops ticking.
Be sure and leave at least 2" of air space between the insulation and the underfloor. Insulate real good to minimize back loss.0 -
Thanks for the feedback! Barrier pex it is!0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
