Cleaning Big Mouth Vent
tkos115
Member Posts: 94
I was wondering if there is a way to clean a big mouth steam vent. In my case it would be more of a question for preventable maintenance. Mine is still working fine, but I was wondering if its worth cleaning them maybe once a year with water or some other solution.
The face plate, with the large hex nut unscrews exposing the o-ring and the element. You can rise it out if it seems to spit water or seep steam, otherwise I'd not bother with it. Both the o-ring and the element are replaceable should they fail.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
