Bosch FW 200, Error code 13 reset
davhead
Member Posts: 12
I had a power surge that took out my 24 v. transformer, low water cut-off and supply temp sensor. Everything is now working, but FW 200 is Showing "fault 13". Anyone know how to reset this control or is the control damaged also?
I have reset the Heatronix and the FW 200 to factory default settings. Still showing Fault 13.0
- 117 Geothermal
