Radiator EDR help
keith123
Member Posts: 105
I please need help figuring EDR on this type of rad. Thank you
i think you have 14 edr total for those 2 panels https://www.gwgillplumbingandheating.com/webapp/GetFile?fid={86A4558B-A052-4675-9D83-6628E4E38694}
Located in durham NC.
At that angle it's hard to tell how tall it is. If those wall tiles are 12" high, they'd be 9-Bs instead of 7-Bs. In that case the EDR would be 18. @keith123, can you measure the height of the radiator?Just another DIYer | King of Prussia, PA
Actually, @luketheplumber, you're probably right. That TP holder is probably 4", high, so that would make the tiles 8" high.Just another DIYer | King of Prussia, PA
I have three all together. All are 21” wide. Heights are 25 x 2 and one at 38”0
Do you have a picture of the 38" tall one? American didn't make the wall radiator in that size, so it must be a different make.
American made five different units that could be put together to build larger radiators. This is a summary of the units' sizes and EDR values:
height width EDR
5-A 13⁵/₁₆ 16⅝ 5
7-A 13⁵/₁₆ 21⅞ 7
7-B 21⅞ 13⁵/₁₆ 7
9-A 13⁵/₁₆ 29¹/₁₆ 9
9-B 29¹/₁₆ 13⁵/₁₆ 9
The radiator you pictured looks like it's made up of two 7-B units.Just another DIYer | King of Prussia, PA
thank you for your help !!!0
