Proper oil pressure
zepfan
zepfan Member Posts: 458
What is the proper oil pressure of a waste oil burner? I have a lot of experience with regular oil burners where I am used to seeing 100-150psi, but this is the first waste oil heater that I have worked on. The unit in question is an Energy Logic
Model MH 15602
Serial AS461212
Thanks to all
  • STEVEusaPA
    You should get a manual and check, or call their tech support. Pressure is can even be very high 200-300psi.
  • BDR529
    BDR529 Member Posts: 376
    Completely different animal. Start with 2 PSI oil and 10-12 PSI air, -3 Nozzle
    They do not self adjust, pay attention to what goes in the tank.
    Steve 200-300psi of what?
  • STEVEusaPA
    edited November 2019
    I was talking about pump pressure. The few I worked on had high pump pressure. Although looking at the manual I see it's low between 3 and 15 psi.
  • BDR529
    Nasty burners. Think of them as a semi controlled tire fire.
    Think the consumer has been mislead with most of them.
    Steamhead Member Posts: 18,501
    ISTR the old Winkler low-pressure burners could burn waste oil.
    Consulting
  • BDR529
    Sure can this one has 2 nozzles
    EdTheHeaterMan Member Posts: 12,190
    Here is your owners manual.
    https://www.energylogic.com/_assets/pdf/support/Furnace_Installation_and_Operation-115V_UL.pdf
    Energy Logic has authorized dealers that can provide service. I live in an area where the authorized dealer is over 3 hours away round trip. So I get this call to look at one, Took me several hours, over 3 days, to read up on the product then take everything apart, clean the gook out of the preheater, nozzle, and fuel lines, then get it all back together and start it up.
    Now I'm the area expert and not sure I like to be the go to guy for waste oil heaters. I have over 40 years experience on oil heat and I'm pretty good at it, Still took some time to understand concept and sequence of operation for this beast. If you are not good with mechanical things, you might want to call the number in the manual for help.
    Just remember, You are getting free fuel for your heater, Spend some money on qualified service and you will have dependable operation.
