fuel pressure gauge with clear hoses
mikedo
Member Posts: 301
in Oil Heating
years ago i had an oil pressure gauge kit for testing the pump pressure it had clear hoses so you could see the oil flow to make sure their isn't any air bubbles in it. is anyone familiar with it I'm looking to buy one again
Here is the new and improved kit.
the clear tubing is gone. https://www.amazon.com/Westwood-Burner-Pump-Multiple-Burners/dp/B00CMC0VF8Edward Young Retired
Follow-up
the red and blue tubing might be translucent PEX material but hard to look thru to see bubbles.
If you are looking for the line from the tank to the fuel pump, I made my own with clear tubing from the hardware store and a couple of pieces of copper with flare nuts. Place the clear tubing over the copper and secure with hose clampsEdward Young Retired
This is the one you’re talking about:
http://orders.sidharvey.com/product/R34/P115-10
You don’t need to see bubbles when testing pressure, but the vacuum hoses are clear.
