Solar DHW tank with gas backup?
Hi, How about using a non-pressurized tank with a copper coil in it as your heat exchanger? Non-pressurized tanks cost much less. Also consider using a heat pump as backup, to cut the electric demand to 1/3 of what direct resistance would be. Years ago, I think it was American Water Heaters who did make a solar tank with an elevated gas burner in it. Now long gone.
Yours, Larry0 -
They were available for a few years. The HTP Solar Phoenix was a nice condensing one.
Basically the typical gas fired solar tanks just put a port mid way up the tank and put the gas valve/ aquastat there. So the burner turned off when it saw the top 1/2 of the tank hot. Solar coil in the bottom would see any cold incoming water. Typical mid 70% efficiency I suppose.
Certainly a compromise appliance, which limited solar harvest by keep 1/2 the tank out of play by the gas fired component.
Why not separate components, much more selection and better control as to which source runs and when.Bob "hot rod" Rohr
In addition to being a budget oriented system, we also have a time limit and it needs to be relatively pretty as this is his place of business and will be exposed for all to see. Nobody is going to mess around building an unpressurized storage tank and then have to insulate it, etc only to end up with an eyesore. As far as buying one, the few I priced with dual coils were actually more costly than a DHW tank. At 15,000 BTU design load, it would take 7 lifetimes to break even with a heat pump financially; that's not in the cards.Larry Weingarten said:Hi, How about using a non-pressurized tank with a copper coil in it as your heat exchanger? Non-pressurized tanks cost much less. Also consider using a heat pump as backup, to cut the electric demand to 1/3 of what direct resistance would be. Years ago, I think it was American Water Heaters who did make a solar tank with an elevated gas burner in it. Now long gone.
Yours, Larry0 -
Thank you. As far as separating the appliances, it's a cost thing. He doesn't want to pay the price to add in an LP boiler. The wood burner and solar are existing, and what I've gathered is that the solar was simply supplementing the OWB by backfeeding to the 400 gallon store in it while the radiant slab ran 24/7 with no means of tempering the water, it's quite a work of art. He wants the option to kill the OWB and still maintain functionality inside, even in low sun times, which is why we're adding the storage. I am fairly certain we're going to end up going the way of the 4500W backup, I was just hoping there was an explanation for the lack of a gas fired solar tank. Seems like it'd be a lucrative racket, for the off-grid folkshot_rod said:They were available for a few years. The HTP Solar Phoenix was a nice condensing one.
https://www.bradfordwhite.com/ecostor2™-sc-solar-indirect-system-single-coil-eco-defender-gas-backup-models-closed-loop0
I did actually look into those, and both my supplier and the BFW website say they are discontinued. Very similar to the Combi-Cor from what I gathered, which is also discontinued for some reason. There is a Laars version of the Combi-Cor called a Combi-Heat, but maxes out at I believe 75 gallonskcopp said:https://www.bradfordwhite.com/ecostor2™-sc-solar-indirect-system-single-coil-eco-defender-gas-backup-models-closed-loop
I thought the BW Combi2 are still available?Bob "hot rod" Rohr
Not according to my suppliers. That Laars unit I mentioned above seems to be the same unit as the Combi2 with a different sticker, but I spoke with two different salesmen about it and they both said it had been discontinued. Maybe in lieu of the Laars? Who knows. Or maybe they were both misinformed, which would not surprise me
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
