Help! Boiler not responding to call for heat
christineandjeff2019
Member Posts: 6
HELLO! I could really use your expertise! I have a Laars EBP0110, that is currently not responding to the call for heat. The domestic hot water is working perfectly. The circulator module is on and they are running but the boiler is not responding. Also, it's not tripping any error codes. Any ideas? I would greatly appreciate it!!
Thank you for the response! I just checked and the circ pump is not running. I'm not sure how to confirm call for heat other than that.0
Need some more info, pics of the entire system will help much
D0 -
Here are some. If you need more just let me know!0
It's a little tough because it's in a tight corner. These were the best I could do.0
Looks like you have 2 zones calling for heat. So those 2 pumps should be on. The pipe to the right of the gauge on the top of the boiler should be hot. The boiler looks to have 176* hot water inside of it. If that pipe is not hot there is a good chance that the anti condensing valve is not opening, could be the valve or the board not telling the valve to open.
D0 -
The pipe under the anti condensing valve it hot to the touch, and the one above is barley warm. Any suggestions on which to try first? Thank you for all your help.0
The valve either is not getting power to it, or is getting power and is stuck or just broke. Unless you know how to use a multi meter about the only thing that you can do is tap the valve body with the handle of a screw driver. Try that maybe get lucky and it opens.
D0 -
Multi meter is reading that there is about 24.5V going to it. Trying the tapping method now with our fingers crossed. At least now we have a good idea on what our problem is. You have been awesome. Thank you for taking the time to help! We were lost.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
