Fresh Air Intake Vent Smell
mi26
Member Posts: 3
in Gas Heating
I dropped something on top of furnace in basement. When I reached over to get my nose went across vent in picture. Smelled slight gas. Heater hadn’t come on for about 2 hrs. Had local hvac friend look at it and couldn’t find anything wrong but did notice the slight smell as well. He didn’t do any elaborate testing though. He said it could be gas valve inside furnace not closing all the way leaving some residual gas smell if anything. Or could just be residual gas from the unit running. I’m looking to see if anyone has seen this before ? Leaving gas off. Could it be internal gas valve? Or heat exchanger? Or just residual smell from unit. Links to pics below. One is the vent I smelled gas through. Other are the tubes I was talking about.
https://imgur.com/cSBX783
https://imgur.com/1OWrVAA
I would have it checked by leak testing. If the gas valve is leaking through, it could be very dangerous.Ray Wohlfarth
Boiler Lessons1 -
A manometer was used at gas valve and didn’t show anything when unit went off. Soap bubble test was used on gas valve, fittings and orifice as well. Showed no bubbles.0
Turn the switch off. Fill a spray bottle with water and some dish soap and spray the joints on the gas piping, outside and inside the furnace. Look for bubbles. Dont spray and electrical components.
The furnace should be maintained yearly by a qualified tech regardless.
How large is the equipment room or space that it doesn't need outside combustion air?1 -
> How large is the equipment room or space that it doesn't need outside combustion air?0 -
Do you smell it with the valve off?0
