Navien NR 240A
Tony1953
Member Posts: 5
constant water trickling out the condensate line when unit is off
could it be the heat exchanger? or 3 way valve?
My bad,, you have a Navien, how old? Have you had any water testing done?
D0 -
it is a NR240A0
no error codes and it works normally0
9 years old0
@Tony1953 yeah that sounds like a leaking heat exchanger2
what about the water inlet valve is not closing completely?0
If your fill valve overfills the system, the pressure goes up. If the pressure goes over 30psi, your relief valve will open and leak water, not your condensate line.
Two btu per sq ft for degree difference for a slab0
