hydronic system powerflush?
salio
Member Posts: 18
It seems the UK has a practice of power flushing hydronic heating systems. Anything like that on this side of the pond, or what is the best alternative? I'm talking about flushing out a converted gravity system before installing a new boiler.
@salio we have the equipment to perform the powerflushing of the radiators, system piping and boiler. The equipment that Europeans have are available here in North America.
Every hot water boiler Repipe, replacement, installation and new system install we do gets a powerflushing1 -
Adding a cleaner, hydronic detergent, helps get a good clean system, oils, fluxes, etc.
Old iron pipe systems, cast iron rads and the UK open systems are tougher to get cleaned as the heavy rust particles need a lot of gpm to move out once they are cleaned off.
It takes at least 5 fps velocity to move heavy particles, dirt, rust, through a pipe. In a 1" pipe you need around 13 gpm to get velocities up to 5 fps. It takes a pretty good purge cart to supply that.
I've yet to find a way to flush all the rust from old cast rads, best to keep flow below 4 fps and let the rust lieRust never sleeps!
Add a good dirt and mag sep to any of those old iron/ steel systems when you upgrade them. Especially with small passage mod con HX's.Bob "hot rod" Rohr
Living the hydronic dream1 -
Before you break into the sys with a new install, run a boiler cleaner thru it, perhaps, Sludgehammer, etc. and run the old boiler per instructions.
I use a lawn sprinkler pump to power flush the system.
https://www.lowes.com/pd/Utilitech-1-HP-Stainless-Steel-Lawn-Pump/4640491
or similar pumps. It is amazing how much crap comes out of the sys when you have high flow and high head pump. Pump each zone one at a time if possible and drain thru the boiler.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
