Wiring new blower motor
scuzz21
Member Posts: 5
in Oil Heating
Hello,
I am setting up my new blower motor but want to make sure the wiring is right. The first image is the new motor the other is the old. Does the blue wire go to line 4 and the white goes to line 1 one the new motor?
Is it the exact same motor? I usually look at the wiring diagram.
Old one is a Westinghouse the new is a Packard both have the same specs. I’m pretty sure I’m right but just need reassurance.0
It looks like your white wire is hot and blue is your neutral unless it's a 230v motor and then it won't matter. Do you have a volt meter to test for hot and neutral.0
