Weil Mclain PEG 35 piping
Hello All, installing PEG 35, and I have a one pipe counterflow system, should I pipe the system with two steam header outputs or one as in the manual. I am going to use a drop header and have plenty of room. So Im asking is it better to use 2 steam outputs into 1? Thanks all!
  • lchmb
    lchmb Member Posts: 2,997
    that is the minimum recommended. I always use 2 ports if available.
    Deltat210
