identify this shutoff valve?
rhodebump
Member Posts: 155
Can someone tell me more about this valve? Even better, where I can buy a replacement (and use the insides)?
I have three radiators that use this type of valve, the problem is that there is a built-in bookcase that was built around all the radiators that I would have to take down and try to put back together again. There would be a lot of work.
I was hoping if I can buy these valves, I wouldn't have to do as much work.
Thanks!
Phillip
Thanks!
Phillip
What type of system is this?All Steamed Up, Inc.
Consulting0 -
I doubt you will find replacement bonnets if that’s your question.gwgillplumbingandheating.com
It's a 2-pipe system, Weil McLain LGB-110
If you can't find washers you can cut it out of sheet gasket and use string packing...0
The first pic looks like a steam trap. You can probably buy parts for that. Clean it with sand cloth on the outside you will probably find make and model.0
I have some very similar looking valves on a 1920's system that I just repacked successfully. They have a logo on them but I haven't been able to find out who made them.
Peter0
- 120 Geothermal
