Re-Installing outside gas lines
Laying all new outside gas lines on my mobile home. My question is... What type of Gas line can be laid on top of the ground underneath the home. I plan to use Home-flex underground polyethylene line 18 inches under ground from meter to the corner of mobile home. But that is not allowed on top of ground under the mobile home. Can anyone tell me what is allowed?
By the way, I am in Kingman Arizona.0
If it’s going under the mobile home, why can’t the gas line be hung from the floor joists.
You may want to ask the local plumbing inspector.There was an error rendering this rich post.
I'd check with an inspector. Here in MN I'd use either flared copper or FlashShield and suspend it from the underside of the trailer, but I've heard of some states down south that won't allow copper on NG.0
- 15.8K Strictly Steam
