Adding TCV's to control steam convectors?
Chuck_17
Member Posts: 148
Things to consider if adding thermostatic control valves to steam convectors in a building?
A church auxiliary building with three floors. The building has one thermostat on the second floor controlling a zone valve. (the boiler serves the church and two auxiliary buildings)
The basement rooms over heat so the thought is to add thermostatic control valves to the convectors in the basement.
What sort of steam system is it-1-pipe, 2-pipe?
How is the system controlled, beyond the second floor valve/thermostat?—NBC0 -
You should think of how the zones temperatures are being read and controlled first. I like Thermostatic Radiator Valves just fine but they are frequently used as Band-Aids in lieu of a proper fix to somewhat flawed system.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Two pipe.
One zone thermostat on second floor for a 11,000 square foot building.
The TCV's would be on some lower level (basement) convectors to control over heating.0 -
Fixed orifices in the overheating convectors would be my suggestion. Start small and you can drill them larger if needed.
10% of the cost of TRV controls.
It is a certainty that some one will fiddle with the TRV and assure themselves they would turn the heat down when done with the area.....but forgets. Then you are right back with the overheating.
This is from servicing 3 churches, 5 schools and a community center with 10 Tstats.
The simpler and less adjustable controls are the better.0 -
Are the basement steam pipes insulated?Chuck_17 said:The basement rooms over heat so the thought is to add thermostatic control valves to the convectors in the basement.
Where are you located?All Steamed Up, Inc.
Consulting0 -
Good question - pipes are insulated.
Upstate NY
