wiring diagram needed
zepfan
Member Posts: 444
I wanted to see if anyone would have access to a wiring diagram for a nesbit rooftop unit of the following model number RSV6005ZZZZHHMB0000
Serial number 80024B5498
From what I understand the company that makes these units are no longer around, and the units were produced in the late 70's early 80's. We have inherited a job that has six units of the same model number without any type of wiring diagram in sight.
Thanks to all
Thanks to all
Did you try here?
http://www.rsicomp.com/nesbitt/parts.htm
Considering the website's copyright is 2011, may not be in business.There was an error rendering this rich post.
Nesbitt is owned by Engineered Air. Google it and it will come up
Are those multizone units??0 -
Thanks. The unit is vav not multi zone
