Taco zvc 404
duartelu86
Member Posts: 2
Is it possible to run a 8 loop uponor manifold with thermal actuators using zvc404. I have 4 loops down stairs for zone one. Two loops for zone 2 and single loop for 3&4
Here's a discussion of the subject:
https://forum.heatinghelp.com/discussion/161320/actuators-t-stats-vas-oh-my8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
> @duartelu86 said:
> @hvacnut how should I wire it up?
Unless I didn't read your post correctly, its fairly simple.0 -
@duartelu86 - It depends on what the water content of your boiler is, the heat loss of the smallest zone, the lowest turndown rate of the boiler if it has one. Describe your boiler and system.Steve Minnich0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
