Insert check valves.
JohnNY
Member Posts: 3,317
Has anyone tried using a plastic insert check valve, like the ones found in cartridge pumps but sold loosely, in a valve/nipple/flange anything like that? I have to use a UPS26-150 pump which doesn't come in an "IFC" type version in a tight space where I'll have to pipe in an 1-½" check valve instead.
The 26-150 volute won't take an insert.
https://wattswater.eu/catalog/antipollution-devices/plastic-insert-check-valves/plastic-check-valve-rv-co/
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
I like these: for tight spaces:
https://www.caleffi.com/sites/default/files/file/01021_en18.pdf
Or these:
http://bellgossett.com/hydronic-plumbing-accessories/pump-accessories/check-trol/
What's not to like?!?! Thanks a lot.STEVEusaPA said:I like these:
Classes0 -
These are our new checks, available in all sizes and any connection.
Same Neoperl check as found with circulators, low pop, soft seal, conical "flow friendly" shape.
Unions to service easily, like when teflon tape or other crud gets inside
12 pipe diameters from a circulator discharge, ideally for a check.Bob "hot rod" Rohr
Those are pretty darn, too. Thank you, Bob.hot_rod said:These are our new checks, available in all sizes and any connection.
Classes0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
