Boiler Help
Boilerhelp
Member Posts: 1
in Gas Heating
Looking for positive experiences ONLY with brands/models gas boiler combi before making purchase
Ask your contractor. He/she knows what's best for your application after a heat loss calculation and finding your domestic hot water needs.
He might tell you to forget about a combi.
It's not wise to pick your own boiler and say "put this in". Your contractor needs to be familiar with the system and have parts available if needed for service.0 -
Have had many a positive experience with many brands and models of product.
What @HVACNUT says above is very good advice. I suggest that you follow that advice because products / brands of heating and cooling equipment are served best when they are [sized] to you and your homes needs.
A good thing to do is find a qualified reputable company that can best serve you and the needs of your homes heating requirements and stand by the boiler they recommend.
If you like, you can even try the find a contractor section on this sight.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
