Need an alternative wireless sensor thermostat to the Honeywell for steam
The Steam Whisperer
Member Posts: 1,215
We've been using the Honeywell 8000 series (and a few 6000) stats for several years successfully with 6 wireless sensor averaging in multi-unit steam heated buildings. However, it seems that the Honeywell thermostats are now going the way of the rest of their product line... we've had about 1/3 of the stats installed in this past year go bad and we may have a couple more we just found out about. Any suggestions for stats with 6 wireless sensor capabilities?
This may may be due to a wireless interference, rather than an electrical fault. Maybe there is a channel selector in its setup.
I wish they would make a wireless model communicating through the electric wiring, like the old Radio Shack “plug and talk intercoms.—NBC0 -
I can assure you, Honeywell's redlink is far superior than a 1980s Rat Shack intercom...………..nicholas bonham-carter said:This may may be due to a wireless interference, rather than an electrical fault. Maybe there is a channel selector in its setup.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
The plug and talk, as you may remember used power line communication, so no signal loss in masonry buildings, although it may have had other problems, a system like that would be an alternative to any wireless device with a signal attenuation problem.
In this case, I can hardly believe all the thermostats and their Redlink died because of electrical problems.—NBC0 -
We have had almost no problems with the 8000 or 6000 stats prior to about 6 months ago, just the recent ones. Some just lost time settings , another would not set up temps at programmed times and another would not hold steady temps. Some had wired sensors, no sensors, some wireless sensors.To learn more about this professional, click here to visit their ad in Find A Contractor.0
There are 2 completely different series 8000 , green screen and blue screen. Green Screen 8000 were discontinued about 3 or 4 years ago but still exist for some reason , just like the 7212 economizer controller.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
Many of those have a button battery, (2032?), as well as regular batteries, and maybe if that goes bad, even the 4 AAA batteries can’t hold the settings.
Static shocks might also be to blame.—NBC0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
