combustion results
tempmike99
Member Posts: 2
What are correct combustion results for 80 to 90 percent eff. units while burning propane. Are they the same as nat gas? i know what are the proper results for nat. gas. not sure if propane would be the same, its chemical make up is different. all i can find is its perfect combustion results, not what one would find with a electronic analyzer thanks
thank you not sure why this was so hard to locate.0
