Source for MEPCO radiator valves?
Dave in QCA
Member Posts: 1,806
I am able to find some of the standard MEPCO radiator valves online. They offer some very nice products and I can't find them anywhere. If anyone knows of sources, please post. I am putting links in here for the ones I am interested in.
MEPCO REGULATING VALVE Regulating Valve - Spring Packed, Type SWRF, Model C
http://mepcollc.com/pdf/literature/steam-specialties/2147E.pdf
STEAM SPECIALTIES Mil-Balancer Valve - No. 840A
http://mepcollc.com/pdf/literature/steam-specialties/1568J.pdf
Spring Packed, Type SWRF, Model B Adjustable Orifice
http://mepcollc.com/pdf/literature/steam-specialties/2148.pdf
Dave in Quad Cities, America
http://grandviewdavenport.com
Dave, 7 yr ago I ordered 4 SWRF, Model C's from MEPCO sales rep
out of Allentown,Pa. His name was Bill Spengler, Meier Supply Co.,m 827 Meadow St., Allentown,Pa.18102. Ph# 610-432-9818.
He was great to work with and very competent. Good luck.
Fizz0 -
Thank you for the information!
How do you like that valve?Dave in Quad Cities, America
http://grandviewdavenport.com0 -
@Dave in QCA
Mepco factory contacts
Contact Us
PHONE:(616) 971-3420
FAX:(616) 971-3421
EMAIL:mepco@mepcollc.com
ADDRESS:
3695 44th Street SE
Grand Rapids, Michigan 49512
@EBEBRATT-Ed Thank youDave in Quad Cities, America
Replaced 2 original Richardson's(Wish I had knowlege to fix for originality) at prior residence and put in vacuum; they work fine!0
