REHAU ACTUATORS......
Andy_d
Member Posts: 10
Does anyone know if Uponor or Caleffi actuators will fit on Rehau manifolds?
The expert that would know that will probably respond @hotrod0
how old is the manifold, got a pic? Any Caleffi actuator with. R at the end of the part number fits Rehau manifolds. I’m not sure how far back in the manifold series howeverBob "hot rod" Rohr
Thanks Bob, this is a new install. Not sure why they don't want to use Rehau actuators. Maybe the Caleffi Twist-top? I din't see any actuators with an "R" in the catalogue. Here is a picture
656354Rehau on page 58
A TwisTop with end switchBob "hot rod" Rohr
Thanks Rod! Maybe we’ll see you in BC again !0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
