REHAU ACTUATORS......
Andy_d
Andy_d Member Posts: 10
Does anyone know if Uponor or Caleffi actuators will fit on Rehau manifolds?
    EBEBRATT-Ed Member Posts: 20,177
    The expert that would know that will probably respond @hotrod
    hot_rod Member Posts: 27,462
    how old is the manifold, got a pic? Any Caleffi actuator with. R at the end of the part number fits Rehau manifolds. I’m not sure how far back in the manifold series however
  • Andy_d
    Thanks Bob, this is a new install. Not sure why they don't want to use Rehau actuators. Maybe the Caleffi Twist-top? I din't see any actuators with an "R" in the catalogue. Here is a picture
    656354Rehau on page 58
    A TwisTop with end switch
  • Andy_d
    Thanks Rod! Maybe we’ll see you in BC again !
